Hole in Basement Wall
  • mjstehn
    • Apr 2010
    I am not sure if this is the right place to post this or not, hopefully it is.
    I have a hole in my basement wall. It appears that they were originally going to run the water line there and then changed their mind. They patched it, but not well. I am wondering what the best way to patch this hole is? I don't want it to leak water in. I thought I may have to go from the outside. The hole has PVC piping in it. Any suggestions?
    Thanks,
  • jnaas2
    • Feb 2008
    • 213
    Remove the plastic pipe and use hydraulic cement, it expands when it dries instead of shrinking like mortar mix
