I recently repaired an outside wall and need to cover the section in some water resistant material, right now the rest of the wall has tar paper. I can only seem to find that stuff in rolls of like 300 feet any other suggestions?
tar paper/ tyvek substute
Rosin paper is available at Lowe's and HD it's in the roofing section (sometimes flooring).
Smallest roll of tyvek is going to be 3'x150' @ $60
or 9'x150' @ $110
Felt paper/tar paper in the roofing section as well is 3' x 100' @ $15.00
Don't use the rosin paper for exterior use, it doesn't do well with moisture like that.
Tyvek is my pick (without a doubt) I never use anything else on any exterior build/repair......ever !!
Tyvek Substitute
Whatever you do, don't put up plastic as a substitute if you live in a cold climate - the water vapor will be stopped and condense within your wall. There were a few infamous homes around here built that way - the moisture over the years led to mold and rotting of lumber. With respect to smaller quantities, many time building supply stores like Menards will have a scrap pile of scrap or smaller quantity materials that they sell at discount.Drywall Taping & Finishing For Beginners
http://drywallinfo.comComment
