Hi there!
The small cracks appearing in the walls during the winter and disappearing in the summer are generally caused by changes in temperature and humidity. In colder months, the air inside the home becomes drier, causing materials like drywall and wood to shrink slightly, leading to small cracks. When summer comes with higher humidity, these materials expand again, and the cracks often close up. This is a common occurrence in homes and typically not a serious concern. However, if you notice the cracks getting wider over time, staying visible year-round, or appearing near windows and doors, it could indicate a more significant issue like foundation movement. Keeping an eye on them is important, and if you see any significant changes, it might be worth consulting a professional just to be safe.
Cracks appearing in wall
