Prepping a wooden deck and fence before staining
  • Prepping a wooden deck and fence before staining
    Hi all!
    What are the best practices for prepping a wooden deck and fence before staining to ensure the finish lasts? Also, are there particular types of stains that perform better in extreme weather conditions?​
    Hi there!
    Great question! Prepping your deck and fence properly is key to making that stain job last. First up, prep work. Start by giving everything a good clean. A pressure washer can be your best friend here, but if you don't have one, a stiff brush and some elbow grease will do the trick. You want to get rid of all the dirt, mildew, and any old, flaking finish. Once it's clean, let it dry completely - this usually takes a day or two. Next, take a close look at your deck and fence. Any loose boards or popped nails? Fix those up. Then, grab some sandpaper and smooth out any rough spots or splinters. This not only makes your deck safer but helps the stain go on more evenly. Before you stain, consider using a wood preservative. It'll help protect against moisture and sun damage, giving your stain a better chance at a long life.
    Now, about stains for extreme weather. Oil-based stains are great for harsh conditions. They really soak into the wood and offer good UV protection. If you're dealing with scorching sun or big temperature swings, these are a solid choice. For areas with heavy rain or humidity, look into solid color stains. They form a protective film on the surface and are champions at keeping moisture out. Some even come with extra mildew resistance, which is perfect for damp climates. If you're near the coast or dealing with lots of moisture, marine-grade sealers are worth checking out. They're designed to stand up to tough, wet conditions. For places with wild temperature changes, elastomeric coatings are pretty cool. They can expand and contract with the wood, which helps prevent cracking and peeling. Whatever you choose, look for stains with UV inhibitors and mildewcides. They'll give you extra protection against sun damage and mold growth.
    Remember, the key is in the prep work and choosing the right product for your specific conditions. ​
