Concrete vs. Wooden Deck
  • Concrete vs. Wooden Deck
    Hi all!
    I'm thinking about building a deck and considering concrete instead of wood since it seems more weather-resistant and low maintenance. What are the pros and cons of choosing concrete over wood? Any insights on durability, cost, or other important factors?
    Hi!
    Concrete decks are definitely a solid choice (pun intended!) if you're looking for durability and low maintenance. Unlike wood, concrete won’t rot, warp, or attract termites, and it can handle harsh weather conditions without much upkeep. You also won’t have to worry about staining or sealing it regularly like you would with a wooden deck. That said, there are a few things to consider. Concrete can be more expensive upfront, especially if you factor in the cost of proper reinforcement and finishing. It can also crack over time due to shifting soil or freeze-thaw cycles, though sealing and good installation practices can help minimize that. Another thing to think about is comfort, concrete can get pretty hot in the sun and isn’t as forgiving underfoot as wood. If aesthetics matter to you, stamped or stained concrete can give you a more decorative look, but some people still prefer the natural warmth of wood. Ultimately, it comes down to your budget, climate, and how much maintenance you’re willing to do. What’s the main reason you’re leaning toward concrete?
      I personally prefer wood over concrete for decks because wood brings a lot of character and warmth to outdoor spaces. While concrete is durable and low-maintenance, it can sometimes feel a bit cold and industrial. Wood, on the other hand, has a natural beauty that ages gracefully (if properly maintained) and offers a more inviting feel. Plus, with the right stain or finish, you can really enhance the look to match your style. That being said, it does require more upkeep to protect it from weather and pests. It really comes down to whether you prioritize aesthetics and feel over maintenance and longevity.
        Good points all around! I’d say it really depends on the look and feel you want. Concrete is definitely low-maintenance and built to last, but I do love the warmth and character of wood. A well-maintained wooden deck can look amazing for years, though it does take more upkeep. If you're set on concrete but want a more natural vibe, maybe stamped or textured concrete could be a good middle ground?
          Thanks for the great input, everyone! I can definitely see both sides now. Concrete's durability and low maintenance are really appealing, especially since I don’t want to deal with regular staining and sealing. But I do agree that wood has a certain charm that’s hard to replicate.
          FatimaandAhmed – Good point about the heat issue! I hadn’t really thought about how hot concrete can get in the sun. Have you seen any good solutions for that, like coatings or lighter colors that help with heat absorption?
          Annahmed – I totally get what you mean about wood feeling more inviting. Do you think composite decking offers a good middle ground? I like the idea of getting that wood look without as much upkeep.
          Tomhanks – Stamped or textured concrete is an interesting idea! Any designs that mimic wood well?​
            Yeah, concrete can definitely get hot, but there are a few ways to make it more comfortable. Lighter-colored concrete reflects more heat, so choosing a light gray, beige, or white finish can help keep the surface cooler. Stamped or textured finishes also don’t absorb as much heat as smooth concrete, and they give a nice decorative touch too. If you’re open to coatings, cool deck coatings (like those used around pools) are designed to reduce heat absorption and can make a big difference.
            Another simple option is adding a rug or outdoor mat in areas where you’ll be walking barefoot. And if your deck gets a lot of sun, having a pergola, awning, or even a few large potted plants for shade can help keep the whole area cooler.
              Yeah, composite decking could definitely be a good compromise! It has the look of wood but doesn’t require as much maintenance since it won’t rot, warp, or attract pests like natural wood does. Plus, you won’t have to worry about staining or sealing it every few years. It’s also more comfortable underfoot than concrete and doesn’t get as hot. That said, composite can be pricier upfront compared to both wood and concrete, and some brands can fade or scratch over time. It also doesn’t have the exact same natural feel as real wood, but higher-end options come pretty close. If you like the idea of low maintenance but still want a wood-like look, it’s definitely worth considering.
                Yes! Stamped concrete can do a great job of mimicking wood grain, and there are plenty of patterns that resemble natural planks. Some even have realistic knots and textures. You can also choose stains to match different wood tones, like warm oak or weathered gray.
                  Thanks for all the great insights, everyone! I really appreciate the different perspectives on wood, concrete, and composite decking.
                  Those wood-look stamped concrete designs sound really interesting! Do they feel textured underfoot, or is it mostly a visual effect?
                    Stamped concrete does have texture underfoot, but the level of depth depends on the pattern and how deeply it's stamped. Some designs have a light texture, similar to slightly weathered wood, while others can be more pronounced, mimicking the grooves and grain of real planks. If slip resistance is a concern, you can add an anti-slip sealer or a fine grit additive to the surface to improve traction, especially in wet conditions.
                    • #11
                      That makes sense! How often do you need to reapply the sealer to keep it slip-resistant? Also, how does stamped concrete hold up in really hot or cold weather?
                      • #12
                        Sealer typically needs to be reapplied every two to five years, depending on the wear and tear, weather exposure, and the type of sealer used. High-traffic areas or places exposed to a lot of moisture might need resealing more often. If you're using a grit additive for slip resistance, you may need to mix it into the new coat when resealing to maintain traction.
                        As for extreme weather, stamped concrete holds up well if properly installed and maintained. In really hot weather, darker colors can absorb heat and become warm underfoot, but lighter shades help with that. In freezing conditions, the biggest concern is water seeping in and causing cracks due to freeze-thaw cycles. Using a high-quality sealer helps prevent this by keeping moisture out. If you're in an area with harsh winters, it's also best to avoid using de-icing salts, as they can speed up surface wear.
                        • #13
                          Thanks for the insight! If I go with stamped concrete, what’s the best way to keep it safe in winter without damaging the surface?
                          • #14
                            The best way to protect stamped concrete in winter is to avoid de-icing salts, as they can cause surface damage over time. Instead, use sand for traction, it won’t harm the concrete. Also, keeping the surface sealed helps prevent water from seeping in and causing freeze-thaw damage. If snow or ice builds up, using a plastic shovel (rather than metal) can help prevent scratches.
