Anchors to attach cat pen to house?
  • Flasharino
    • Mar 2011
    I have a couple of indoor-only cats and I'd like to build a fenced-in pen attached to the house which they can climb in and out of when the weather permits via an open window. I am thinking I would have to take it down in the Winter (lots of snow here) so I'd make it modular for easy assembly and storage.
    What I am not clear on is the best way to attach it securely, and temporarily to the house. My siding is 5/8 vertical cedar planking over sheathing so fortunately nice and flat. I don't want to use anything that was proud from the house, I want any fasteners to be recessed or flush. I also don't want the elements to be able to get in through holes when bolts were removed. It would also be nice if I could put it together without tools, maybe with wing-nuts or something like that. Then of course the material has to all be rust-proof.
    Any suggestions as to what sort of fasteners I should use and maybe links to examples? Thanks.
  • thedcdude
    • Jan 2006
    • 82
    How about not fastening it to the house. Hammer posts into the ground right up against the house.
    • Flasharino
      • Mar 2011
      I am planning to put the pen on my deck, not over the ground, which is part of the reason I want the fasteners to be flush. I was planning to connect it to the deck as well as the house. I don't want to take a chance that the cats could get out through any gap between the pen and the house. I also want to screen it in so that no disease-spreading mosquitoes can get in through any gaps so I am really looking at the fasteners.
        use a set of heavy duty hinges with removable pins.
        • Flasharino
          • Mar 2011
          Yeah, thanks that's not a nad idea, but I am not crazy about having the half-hinge permanently attached to my house.
            have you tried velcro?
