Hi we have oil heat and therefor an oil tank in the backyard. right now it has 4 legs sitting on 4 what looks like small concrete panels. in the middle is dirt and it looks like the previous owners out weights in the dirt to keep it from settling and moving is my guess. well it looks horrible and one of the slabs broke the the tank is leaning some. Originally i wanted to move the tank pour a concrete foundation and put the tank back. Well i have no idea how i would move the tank to i was thinking of pouring a concrete foundation around the legs and somehow just raising the broken corner. Is this possible/ a good idea, any help is greatly appreciated, thanks.
concrete base for oil tank
go to the harbor freight store and get a dc powered fuel pump or a pump that goes onto a pistol grip drill and a short length of garden hose with fittings. get a five foot length of pvc pipe. put the pump together with the hose and pvc and pump out your tank into a 55 gallon drum. the drum only holds 55 gallons, so if you have more fuel, use more drums. Ideally your tank base should include provisions to contain any spillage, a curb, so to speak of if fittings leak or the tank itself leaks. when you place the tank, elevate the "out" end slightly above horizontal so that condensate water drains into the other end and it doesn't freeze in the outlet pipe or tubing going to the heater. -
If you jack up one end at a time you would not need to take the oil out. Put a plank the long way of the tank on the ground and put your jack under the end of the tank with a piece of wood between the jack and tank. When the tank is full of oil it can weight more than 2000 lbs so if it was mine i would use a 8x16x4
solid slab block under each leg. You should have a drain at one end of the tank
to drain the water out of the tank. Leave that end of the tank just a little lower
to drain water off. Your suction and return oil lines go into the top of the tank, so you suction line will have drip leg inside of the tank that would be a few inches off the bottom of the tank. paulComment
jack
I do not think a regular car jack would keep it up. Now that depends on the jack. If the jack hook fits into a slot on the car body then NO it wouldn't work. If it's a scissors jack, then I'd be more inclined to use that.
slate is apt to crack unless it is about two inches or more thick.Comment
Kerosene weighs slightly under 7 lb / gallon so at 275 gallons your looking at 1,850 lbs. full your looking at 5,500 odd pounds, you cannot sit that on slate. You would be better and cheaper getting some precast concrete paver slabs (2'x2') over a good crushed granite base, both available at any big box store.
