does anyone have insight about removing chimneys (i.e. alternative venting, converting natural fireplaces to gas, etc.) to make more roof-space for solar PV arrays?
Sorry, I don't have any professional things for this but, sounds very do-able. . . The draft for a natural Gas Fan Assisted Appliance is MUCH less than a natural draft fireplace. Do you know how many BTU's the fireplace you are considering is (I'm sure I can help if you get me the BTU's)?
thanks!
Hi Paul here . You did not give enough info for anybody to engineer anything.
Also HayZee518 was right in his statement about Canada having a different codes. Quit often there code's are a lot different then ours is. So you need to figure out what you want and have it engineered by a co. that knows you code for you area. Paul
Hello all. I'm in the midst of planning a much-needed makeover for my home's interior, and I could really use some expert advice and creative ideas. My...
