While out on my front patio this past week, I noticed what looked like a small paint flake on the upper flashing of the overhang. I discovered the paint flake was a hole into a carpenter ant nest. I ripped out the flashing as well as all of the damaged/rotted wood. There are two planks that run from the front post to the side of the house. I assume these are load bearing. One of the planks was damaged enough that the remainder of it will definitely need to be removed. The other is in decent shape. The damage/rot doesn’t appear to extend to far ends of planks, so I don’t believe the ants made it to other sections of the overhang.
My questions are:
1. How long are the planks? Do they extend into the house to provide load bearing for the second floor?
2. Not knowing the building codes, can/should the planks be removed without worrying about the any structural issues that may cause inside the house?
Any suggestions would be much appreciated.
My questions are:
