Leaky Skylight.... the glass leaks
  • andyhoff
    • Nov 2005
    During heavy storms, water leaks in between the glass and the edge of my skylight. I confirmed this by using a hose. In the past, I've used a silicone sealant, but, I'm thinking that didn't do the trick. If it did, it was only for a short while. How would you suggest I combat this very annoying leak.
    Thanks in advance for any help!
    Andy
  • lonestarheir
    • Jul 2005
    • 137
    It could actually be running up under the flashing and getting in that way, take a look at the sealant around the flashing.
    Brandon
    Brandon
