Egress window well cover...
  • DKAudio
    • Apr 2006
    • 454
    I want to purchase a egress window well cover to keep debris/animals from getting in and from humans falling in. I went to a couple big box stores and actually purchased one for $130. I got it home and it is ugly, no way can it support a full grown human, and I cannot open my window with it on (it is the kind that sits on the well). With the way the install worked out the top of the window is a little above the metal well. Therefore, I am looking for a cover that has some sort of walls to build it up a few inches, it would be nice to have a hinged top too. Cost is an issue and $130 was a lot for me right now. I will return that one but am wondering if anyone had any suggestions.
    Thanks
  • tezza
    • May 2009
    hmm from what ive seen these covers come at a price and will be hard to find somthing similar for under 130$. i think the only option is to w8 and try to save up some money for it other than that ebay ? havent looked but a possibility
    • Sonny
      • Jul 2012
      Dimensions?
      Do you have dimensions? It's hard to make a recommendation without knowing what will fit. For the most reliable load bearing surface in your price range you could go with a grate cover but you would have to build up the edges of your well in that case because they lie flat and would block your window as well.
      • DKAudio
        • Apr 2006
        • 454
        This thread is 3 and a half years old. I just built a pressure treated frame and used acrylic on top.
