Dealing with vinyl single hung windows:
Noticed after a previous day of hard rain 1st floor ceiling appeared to have leaked right at the outer wall.. checked upstairs and couldnt find anything... some folks working on repairs next door came over and took a look.. suggested re-caulking the upstairs windows as it may be rain getting inside the wall and finding its way down... seemed reasonable as the window was in close line to the leaking area..
however.. rained again tonite.. noticed a differnt leak at the TOP edge of downstairs window.. (which is directly below the second floor window).. but no apparent opening on outside where water could get in... very well sealed... and the leak generated more water then could be coming through any of the above floors window caulking.. i gather water was definitley getting in between the walls somewhere coming from the above floor.. again went to upstairs window.. nothing apparant... opened window and noticed the bottom tray where the window closes into.. was full of rainwater.. VERY FULL... now either it is supposed to drain out through somewhere or the water shouldnt be getting in there.. Again, this is where the bottom edge sits into the track when closed.. there is weather striping in the form of a fiber/bristled material strip on outside of window right above the closure... also.. noticed alot of mold in the bottom tray.
So my question.. is it normal to fill with rain water? and if so how does it drain? and if it does drain, can mold be clogging the route? Now, if its not supposed to fill with water what can i do.. seems the weatherstripping was entact? Or, is this not the likley cause of the leak after all?
Again, vinyl windows by Jeld-Wen, flat bottom sill no slope, house built in 2005. Thanks in advance for any assistance.. Ritch in Houston, TX
