How do go about repairing this at the entrance to the unheated basement garage at the side of the house? The garage floor is seriously cracked, also, due to water getting under the slab and freeze/thaw.This is the only side of the house where the basement opens at ground level. The other 3 sides are back filled with sand.
Cracked footing?
I'm surprised the concrete contractor didn't put in an expansion strip somewhere in the pour or used re-bar in the slab. your cracking longitudinally explains that. now for the repair. use a soupy mix of hydraulic cement and pour it into the crack. hydraulic cement will expand when it cures. after it has cured use regular mortar mix with a cement bonding agent and build a "cap" over the sill. -
Well it you could also use polyurethane based concrete repair formulations. They are polymer coated to provide extra strength.Comment
by AlphaWhat’s the best way to prep roofing to avoid ice dams and leaks?
