I am having lap siding installed on my house. There is z flashing above all windows and the garage. The seam between the flashing and the siding, the top of the horizontal portion of the z flashing, has been caulked. Looking at the installation instructions of the siding (figure 7 page 2, of james hardie's installation insturctions) it states not to caulk this area. The contractor already caulked this area. What are the risks of having the caulk there?
Caulked Z flashing
Thanks. I just wanted to get a second opinion. I spoke to the contractor about this and he gave me a winded reason why he did it. For me, I don't see why anyone would install z flashing if they decide to caulk it. There wouldn't be a reason, that I know of, to stick some z flashing in caulk.Last edited by zeal; 12-06-2009, 02:26 PM.Comment
Hi Zeal,
Like pushkins said this area should let moisture out if for some reason above that point water got behind the siding. If the top edge of the "z" flashing is taped or put under your house wrap, when water gets behind the siding it will run down the house wrap or wall and hit the "z" flashing and run out so it doesn't run into the wall around the window.Comment
by AlphaWhat’s the best way to prep roofing to avoid ice dams and leaks?
