I have a metal exterior door that is a source of heat loss. The door and frame came as a package and was installed when the house was built about four years ago. It has a built-in weatherproofing strip that is fine about halfway up from the threshold, but at that point the door and strip start to lose contact (this is opposite the hinge side).
Up to the corner of the door (above the door knob) it completely loses contact and opens up to about a 1/4" gap where a lot of cold air gets in. To make matters worse, it faces north, so the wind blows in quite a bit. At the top of the door, it is still open 1/4", but then the gap closes again as it gets closer to the hinge side.
In the past, I put on a self-sticking weatherproof strip on top of the existing strip, but (1) it doesn't stick very well due to the cold weather, and (2) it compresses the existing strip so there is still a gap in a couple of places.
I don't know if the door is warped at the top corner, or if the frame is warped. Either way, the door doesn't seal off well and we've got some serious heat loss.
Any other ideas for fixing this, outside of pulling off the door and frame?
