I have the following garage door opener:
Model: 139.53635SRT H.P: 1/2 Brand: Craftsman
The garage door would close and reach the bottom of the concrete and then automatically reopens again.
Here's what I found out. One of the sensors is acting weird. Regardless if I block the sensor or not, it's green. On the right sensor, if I block it with my hand, the light went out. So, it seems that something is wrong with the left side sensor. Is this behavior normal? If not, is there a way to fix this?
There are a number of things that cause this, could be that it just snapped and is no longer making contact. if nothing is broken (very easy to tell from a visual inspection) just pull out a screw driver and turn until the limit comes back to the right spot
