Linear Garage Door Opener Troubleshooting HELP!
  • morgantician
    • Nov 2013
    Hello! I am in need of some help troubleshooting my Linear garage door opener (model 20030317D0152). We bought a house last spring and during inspections the door worked just fine, but after we moved in it suddenly didn't work. I didn't bother trying to fix it as summer was approaching and we didn't need the garage, but now Minnesota winter is coming.
    Here's the scenario (also of note: I am a licensed electrician and proficient with testing equipment, but inexperienced with small electronics like this, especially garage openers):
    The wall switch nor the remotes will initiate the motor. And I mean nothing - the chain doesn't move, motor doesn't try to engage, light doesn't come on. Looks as if there was no power to it at all(but I assure you there is 120v to it - first thing I checked).
    I did a continuity test of the wires going from the opener to the wall switch and both rung out clear. I have lights on on my ground sensors which correctly change when I block the beam. When I hit the wall switch absolutely nothing happens, but when I hit the remote switch the "learn" light temporarily blinks. Nothing will turn on the 120v light bulb on the opener at all (the bulb is good though, I checked).
    Some more specifics: checking voltage at the wall switch I have nothing when the switch is pressed or depressed (normal minuscule DC mv). My chain appears to be correctly on it's track and not bound up - I also turned the dial on the back of the opener to see if it moved freely and it did. When I removed the wires from the motor inside the opener I got continuity from both the red and blue leads to it's neutral wire (white) - could this indicate a grounded motor?
    I'm also wondering if there is some sort of internal fuse that may have blown that I can't find. As I said, I'm inexperienced with these things so I tried to test all my basics before I sought out help or...dare I say...call a repairman.
    Any help or direction is appreciated! Thank you!
  • TJR
    • 175
    Some has a wall control with a light and lock function, make sure the lock is not on, but the work light should blink when use the remote.
    So that leave you with a possible board failure inside the opener.
