Liftmaster Opener Help
  • Gigem085
    • Aug 2011
    • 20
    I am trying to repair a Liftmaster opener. The gears (plastic) were shredded so I ordered the main gear and worm gear, which I replaced. I reinstalled everything then tired to test it out. I heard a pop and flash whcih tripped the circuit to the outlet. I reset the breaker in the panel, now when I press the opener, it make three clicks and nothing happens (motor does not operate).
    Any ideas on what to do now?
  • TJR
    • 175
    Most likely you short out the logic board, but IF you are lucky it was the start capacitor that went of with a puff of smoke and black stuff inside the box.
    • Scarhole
      • Dec 2013
      • 5
      You prolly cought a wire under the metal gear plate.
      i did it before , pc boards prolly burned.
