This is a 1/2 HP chain drive opener that recently started refusing to close reliably. Symptoms are:
So far I have:
Either it's something simple I've not thought of, or something complex like ckt problems on the logic board or the "flywheel strobe" sensor that I'm guessing checks for closing resistance. Any ideas or suggestions for further checks?
Thanks! -Paul
- Door begins to close, after ~2 to 5 feet of travel it reverses and the light blinks as if an obstacle were encountered. The "trouble spot" is not consistent run to run.
- Disconnecting door from the carriage makes no difference. This made me suspect the chain and track (see below). By hand the door travels easily.
- I can make the door close by hitting the switch quickly after a reverse (which stops it), and hitting again to resume the close. Sometimes this only takes 3 iterations. Sometimes well more than 10.
- It seems worse in colder temperatures.
So far I have:
- Greased the chain
- Tried increased and decreased chain tension
- Lubricated the door rollers
- Felt along and visually inspected the chain guide for obstacles
- Increased and decreased closing force to the extremes
- Greased the internal drive gears
- Verified that the limit contacts are placed appropriately and working
- Checked sensor alignment and verified they work
Thanks! -Paul
