Sears Craftsman - 139-18851 1/2 hp (15 yrs old), chain drive
Functions perfectly up to 20 times. Then next day will not function at all - no buzz, no clicks, no flashing light. Neither from remote or hard wired switches.
Found small p.b. recessed on back panel (does not look like p.b.) which is not mentioned in any manuals. Upon pushing this button door works fine again. Obviously some type of 'Reset' button. Rotating shaft by hand also worked once.
Question is: if it's a reset what kinds of things cause it to trip ? Motor has some type of thermal protection but overnight cooldown not solving problem. (Maybe cooldown plus reset required ? ? ?)
Drive worm gears are OK, limit switches OK, photo cells lined up, chain is lubricated, no measruable misalignment of chain or wheel tracks .
Worn brushes wouldn't be fixed by 'Reset".
Does motor need lubrication?
Desparate - this has been going on for a month. Bought new unit on sale yesterday, but would prefer to fix existing rather than have to replace tracks and chain as well as operator - apparently new chain sprocket not compatible with old ? ?
