Marantec 4700E error code 1,7,8
  • StreetGlow
    • Dec 2021
    Hi guys
    I have a Marantec 4700E model that's giving me issues after 7 yrs. Been running good all this time but today it will just open but not close. Only way it will close is if I hold the wall button and not release it until it's closed all the way. When I check the error codes #1,#7 and #8 lights are blinking. When I check the manual it says Force watchdog circuit found an error or the sensor which monitors the operator sensitivity has failed. For solution it says to readjust operator force and run the operator for 2 uninterrupted complete cycles, Level 1 (Menu 1 and 2). I'm not sure how to do this. Any help would be much appreciated. Thanks guys.
  • machinist
    Moderator
    • 386
    Hi!
    It sounds like your Marantec 4700E garage door opener might be having issues with its force settings or sensors. To fix it, try adjusting the down force settings on the opener by turning the screw clockwise to increase the force, then run the door through two complete open and close cycles without interruption. Make sure the safety sensors are aligned and clear of obstructions. If you still see the error codes, it might be worth consulting the manual again or reaching out to Marantec support for more help.
