Liftmaster problem
  • I'dluv2
    • Oct 2022
    Liftmaster problem
    I have 2 doors I'll call A & B. A works fine now, and B works within limits. 2 remotes both work on A, neither on B. Figured maybe needed re programming but still no go. Door B works with button on wall, light comes on . If B is open & I close and break the beams it goes up and flashes like normal. If both doors are up and I walk thru the beam the light comes on for A. If I walk thru the beam on B light doesn't come on. Only thing I can think is maybe something on the board went haywire.
    I replaced the board on A 2 years ago and everything is fine now. Any guesses or ideas are welcome.
  • machinist
    Moderator
    • 388
    Hi!
    It sounds like Door B might have a few issues with its safety beams or control board. Since the remotes aren’t working but the wall button does, and the safety beam light doesn’t activate properly, it could be a problem with the sensors being misaligned or the board not processing signals correctly. Double-check the sensor alignment and wiring for any issues. If everything looks good there, it might be worth looking into the control board for Door B or consulting a pro for a more thorough check. Hopefully, these steps help you get things sorted!
