Greetings all,
I have a Sears self propelled (front wheels) push mower that has some sort of engine problem. Here is what I have done so far:
Replace oil
Replace air filter
Replace spark plug
New Gas
Replace blade (just part of getting ready for spring mowing)
The engine starts easily and runs smoothly. It runs until it just begins to sputter and stop. This happens after about 30 minutes or so of use. What could be causing this? Carburetor? Heat?
I let is sit for 30 minutes (cooling down perhaps) and it starts right up to repeat the process. Any suggestions on what the problem is for you small engine guys and a solution.... Thanks for your help.
Replace oil
Replace air filter
Replace spark plug
New Gas
