Hello HRF,
I have a sears gas trimmer that needed the fuel lines replaced.
I, however, didn't take note of how the lines were routed when I removed them.
Does anyone have a similar trimmer, and can tell me which lines run where?
There are two lines from the fuel tank.
One goes to the primer bulb, the other goes directly to the carb.
There are two barbs on the carb, one is high, the other is low.
So does the line from the primer bulb connects to the high or low barb on the carb?
Thanx.
Thanx.
