John Deere L110 brake noise issues
  • Wardo5000
    • Jun 2009
    Hello All:
    I have a four year old JD L110 and recently I have started to have noise issues when releasing the brake from the lock position. Well it started when I hit a root in some long grass and salled out the mower, but that is another story. Anyways, when I release the brake from the lock position a awful rattle / grating noise starts and when I depress the brakes it stops. This trouble sometimes is intermittent. When I look under the unit (as it it running) the brakes need to be locked so I can not troubleshoot this. Anyone have this problem or have any ideas to fix the problem?
    Deere machine...
    Hi, Wardo5000. Welcome to HRf. To get an in depth answer to any John Deere issues, join this forum:
    Weekend Freedom Machines: <b>Restoration and Repair Forum</b>
    Register there, and post your problem in the either the General Repair, Hydrostat or Gear Drive topics. Lots of Deere knowledge and helpers there. It's the Deere equivalent to HRF....
    mrcaptainbob.
    • Wardo5000
      • Jun 2009
      JD L110 noise issue
      Still no answers as of yet
      Hello All:
      I have a four year old JD L110 and recently I have started to have noise issues when releasing the brake from the lock position. Well it started when I hit a root in some long grass and salled out the mower, but that is another story. Anyways, when I release the brake from the lock position a awful rattle / grating noise starts and when I depress the brakes it stops. This trouble sometimes is intermittent. When I look under the unit (as it it running) the brakes need to be locked so I can not troubleshoot this. Anyone have this problem or have any ideas to fix the problem?[/quote]
        brake noise...
        Are you saying you joined that forum, posed the problem and nobody replied??! I cannont find your posting on it. Which part of the forum did you post and when?
