Hi there! Is it necessary to use a primer when painting over dark-colored walls, or can high-quality paint provide good coverage on its own? Thank you.
Painting over dark-colored walls
Hi Downaski!
While it's true that premium paints offer better coverage, using a primer is still generally your wisest choice, especially if you're going for a lighter color. Primer creates a uniform base, which not only helps your new color pop but also saves you time and paint in the long run. You'll likely need fewer coats, and the primer improves how well the paint sticks to the wall. Plus, it can block stains and prevent that pesky dark color from bleeding through. That said, if you're painting dark over dark, you might get away without primer. But for most color changes, particularly to lighter shades, a good primer is your ally for achieving that perfect finish.
For primer: 1-2 coats are usually sufficient. One coat might be enough if you're using a high-quality, tinted primer specifically designed for covering dark colors. However, for very dark or vibrant base colors, you might need a second coat of primer to fully obscure the original shade.
For paint: 2-3 coats are often necessary. After priming, you'll likely need at least two coats of your light-colored paint. Some very light colors, especially yellows or pastels, might require a third coat for even coverage and to achieve the true color you're aiming for.
Keep in mind that these are general guidelines. The exact number of coats can vary depending on factors like:- The specific shades you're working with
 - The quality and coverage of your primer and paint
 - The texture and condition of your walls
 - Application method (brush, roller, or sprayer)
It's always a good idea to assess the coverage after each coat dries and decide if another is needed. Patience is key - allowing proper drying time between coats will give you the best results.
