Performance issues!
  • Downaski
    • 409
    Performance issues!
    What are some good ways to troubleshoot a laptop that's acting up with sudden slowdowns and high CPU usage, even though it’s a high-end model with plenty of RAM? I've heard that common fixes like updating drivers and checking for malware don’t always solve the problem. Are there any special tools or methods that can help figure out what's really going wrong?
  • machinist
    Moderator
    • 386
    Here are some easy-to-follow steps to troubleshoot your laptop's slowdowns and high CPU usage:
    1. **Check Task Manager**: Press Ctrl + Shift + Esc and look for apps or processes using lots of CPU, memory, or disk space.
    2. **Monitor Temperatures**: Use tools like **HWMonitor** or **Core Temp** to check if your laptop is overheating, which can slow it down. Clean the vents and fans if needed.
    3. **Change Power Settings**: Go to **Control Panel > Power Options** and switch to **High Performance** mode to make sure your laptop is running at full power.
    4. **Use Process Explorer**: Download **Microsoft Process Explorer** for more detailed info on what processes are causing high usage.
    5. **Check Event Viewer**: Open **Event Viewer** to see if there are any critical errors or warnings that happen when the laptop slows down.
    6. **Check Hard Drive/SSD Health**: Use a tool like **CrystalDiskInfo** to make sure your hard drive or SSD isn’t failing, which can cause slowdowns.
    7. **Disable Background Apps**: In **Task Manager > Startup**, disable unnecessary apps from starting automatically. Also, disable non-essential services using **msconfig**.
    8. **Check for Corrupt System Files**: Run the command **sfc /scannow** in the Command Prompt (Admin) to check for and fix corrupted system files.
    9. **Update BIOS/Firmware**: Check your laptop’s manufacturer website for BIOS or firmware updates, which can improve performance.
    10. **Use Advanced Tools**: If you want a more detailed analysis, download **Windows Performance Analyzer (WPA)**, which can give deep insights into what’s slowing down your laptop.
    Hope this helps!​
