Understanding the difference between DDR3 and DDR4 Rams
  • TinyTool
    • 357
    Recently I am looking to buy a new desktop/tower PC. The person I am buying from have forwarded me a list of motherboard and other pc stuff that I will need on my computer. I do understand the basics but I am a little confused between DDR3 and DDR4. Does the different DDRs have huge difference in performance? Is it better to buy DDR3 16 GB or DDR4 8 GB ram?
    Also does different motherboards support different types of DDR Rams? If I buy DDR4 ram, will I have to buyer a newer motherboard?
    Any help in this regard would be very helpful. Please note that I require this PC for mostly work purposes. Multitasking, spreadsheets, browsing, etc..
    Thank you!
  • machinist
    Moderator
    • 386
    Hi TT! Let me explain this in a simple way.
    DDR4 vs DDR3 key differences:
    1. Speed: DDR4 is significantly faster than DDR3
      • DDR3 typically runs at 1333-2133 MHz
      • DDR4 typically runs at 2133-4800 MHz
    2. Power efficiency:
      • DDR3 runs at 1.5V
      • DDR4 runs at 1.2V (more energy efficient)
    Regarding your specific questions:
    1. Motherboard compatibility:
    • Yes, motherboards only support specific RAM types
    • You cannot mix DDR3 and DDR4
    • If you buy DDR4 RAM, you MUST have a DDR4-compatible motherboard
    1. DDR4 8GB vs DDR3 16GB: For your use case (multitasking, spreadsheets, browsing), I would recommend going with DDR4 8GB for these reasons:
    • Better future-proofing
    • Faster performance
    • You can always add more RAM later
    • Modern applications are optimized for DDR4
    My recommendation:
    • Go with DDR4 RAM and a compatible motherboard
    • Start with 8GB if budget is tight
    • Consider getting 2x4GB sticks for dual-channel performance
    • Make sure your chosen motherboard has additional RAM slots for future upgrades
    • TinyTool
      • 357
      Thank you. When you say dual-channel performance, how exactly does that work with the 2x4GB setup? Will it make a noticeable difference in my everyday tasks?
      • machinist
        Moderator
        • 386
        Think of RAM access like reading data from storage. With a single stick of RAM (single-channel), your computer has one "lane" to read/write data. When you use two sticks (dual-channel), like 2x4GB, your computer can read/write data using two "lanes" simultaneously.
        For your everyday tasks, you would notice the difference mostly when:
        - Opening multiple browser tabs
        - Working with large spreadsheets
        - Switching between different programs
        - Loading documents or applications
        The performance boost is usually around 15-20% compared to single-channel setup. It's not huge, but it's noticeable enough to make your computer feel more responsive during multitasking.
        However, there are two important things to keep in mind:
        1. The RAM sticks should be identical (same speed, brand, and size) for best performance
        2. Your motherboard needs to support dual-channel (most modern ones do)
        What's nice about starting with 2x4GB is that you can always add another pair later if you need more memory, while still keeping the dual-channel benefits.
        Hope this helps!​
