Urgent help with laptop screen
  • TinyTool
    • 357
    Hi everyone!
    My laptop screen flickers at the bottom whenever I turn it on or when the screen comes back on after being idle. After a while, it returns to normal. This just started happening recently, and it’s been pretty cold where I live.
    I looked it up and saw that cold solder joints might be a possible cause. Does anyone know more about this? Could continuing to use my laptop like this make the problem worse? Would really appreciate any insights!
  • machinist
    Moderator
    • 386
    Hi Tinytool! Sorry to hear about the flickering issue with your laptop screen. It’s possible that cold weather might be affecting the solder joints, especially if they’ve become weakened over time. Cold solder joints can cause poor connections, leading to flickering or other display issues, so you're on the right track with that theory.
    As for whether continuing to use your laptop could make things worse—yeah, it could. The issue might worsen over time if the connection keeps being stressed, potentially leading to complete failure of the display or other components. I’d recommend trying to keep the laptop warm if possible, like using a laptop sleeve or making sure it's in a warmer room. If it gets progressively worse, it might be worth having a technician take a look at the connections and possibly reflow the solder or replace the screen cable.
    • TinyTool
      • 357
      That makes a lot of sense—thanks for explaining! Do you think using an external monitor for now would help take some strain off the laptop screen, or would it not make much of a difference? And is there an easy way to figure out which solder joint might be causing the problem?
      • machinist
        Moderator
        • 386
        Using an external monitor is a smart temporary fix! It can definitely help if the laptop screen is the main issue. By connecting to an external display, you bypass the laptop's screen entirely, which can make it easier to keep using your device without dealing with flickering or display glitches. Plus, it helps narrow down whether the issue is with the screen itself or something deeper, like the graphics card or motherboard.
        As for pinpointing a problematic solder joint, it can be tricky without specialized tools, but here’s a general approach:
        1. Visual Inspection:
          Open the laptop and inspect the connections around the display cable and GPU (if you’re comfortable doing so). Look for cracks in the solder, discoloration, or loose connections. A magnifying glass helps here.
        2. Gentle Pressure Test:
          While the laptop is on, carefully apply slight pressure near the solder joints (use a non-conductive tool, like a plastic spudger) to see if the display stabilizes or worsens. This can help identify weak points.
        3. Thermal Stress Testing:
          Solder cracks can sometimes respond to heat. Gently heating the suspect area with a soldering iron or heat gun (low setting) might temporarily fix or reveal the issue. Be cautious to avoid overheating!
        4. Multimeter Check:
          If you have a multimeter, you can test continuity in the soldered joints. An open circuit could mean a bad joint.
        If you’re not comfortable with these steps, getting it checked by a professional is often the safest route. In many cases, a reflow of the solder (or even reballing, in severe cases) might be needed to fix the issue permanently.
        • TinyTool
          • 357
          Thanks for the detailed explanation! I tested my laptop with an external display, and it works perfectly fine, so it seems the issue is just with the laptop screen. I also noticed that opening something with a white background, like a browser, seems to help restore the display to normal more quickly. Do you think this could be related to the wire connecting the laptop to its screen, or is it more likely a cold solder issue? I’m trying to figure out the next steps!
          • machinist
            Moderator
            • 386
            If the external display works perfectly and the issue only happens on the laptop screen, you’re definitely narrowing it down. The fact that a white background helps restore the display more quickly is super interesting. It could point to something like a loose or damaged display cable (the one that connects your laptop’s motherboard to the screen). When the screen flickers or acts up, slight movements or certain visuals might cause the cable to reconnect just enough to temporarily fix it. This is especially common if the flickering changes when you adjust the screen angle or move the laptop around.
            On the other hand, a cold solder joint (a weak or broken solder connection on the screen’s circuit board) is also a possibility. This could explain why the display reacts to visuals like a white background. Sometimes the brightness or change in electrical flow can momentarily affect the weak connection. The good news is, you have two possible fixes here. If it’s a cable issue, inspecting and replacing the display cable is relatively simple and cheap, especially if you’re up for a bit of DIY. On the other hand, if the issue is a cold solder joint, it can be repaired by reflowing the solder. This involves carefully reheating the joint with a soldering iron or hot air station to restore a solid connection. It’s a bit more delicate, so if you’re not comfortable with soldering, a repair shop can handle this for you.
            If neither fix works or feels practical, the last option would be to replace the screen panel itself. Sometimes, repair shops prefer this route since it’s a quick, reliable fix that bypasses any deeper board-level issues. Either way, since the laptop works fine with an external display, your GPU and motherboard are in the clear, so it’s definitely fixable. Testing things like the screen angle will help confirm whether it’s the cable or the panel causing the issue, and from there, you’ll know which fix makes the most sense for you.
            • TinyTool
              • 357
              I haven't noticed any changes while moving the laptop screen. Does that mean the likely culprit is a solder joint?
              • machinist
                Moderator
                • 386
                Since moving the laptop screen doesn't seem to affect the flickering, it's looking more likely that the issue is related to a cold solder joint rather than the display cable. Cold solder joints can cause intermittent problems like flickering, especially after the laptop has been idle or turned on. Given that the problem seems isolated to the screen, the next step would be to either have the solder joints reflowed or replaced, which can restore a solid connection. If you’re not comfortable doing the repair yourself, it would be a good idea to bring the laptop to a professional repair shop for a thorough inspection and fix. Reflowing the solder is a delicate job, but if it's done right, it can resolve the issue. If the flickering persists after that, or if you prefer a quicker solution, replacing the screen entirely might be the next option to consider. Keep us updated!
                • TinyTool
                  • 357
                  Thanks for the help, machinist. I’m planning to take it to a repair shop, as the situation seems to be getting worse. It’s taking longer for the flickering to stop, and I feel like the flickering is increasing in size.
                  • machinist
                    Moderator
                    • 386
                    Taking it to a repair shop sounds like the right decision, especially since the flickering seems to be worsening. Be sure to describe the issue in detail to the technician, including how long the flickering lasts and any changes you've noticed. This will help them diagnose the problem more accurately. I hope it gets resolved quickly for you! Let me know how it turns out.
                    • TinyTool
                      • 357
                      Hi machinist!
                      I need to update you on a few things. I tried changing my laptop's Hz from 144 to 60 and guess what, it stopped flickering!
                      Also, I took my laptop to a few repair shops, the only permanent solution is to change the entire screen. Currently I am using it on 60 Hz and have not changed the screen yet. But may be later I will!
                      Thank you for all the help!
                      • machinist
                        Moderator
                        • 386
                        You're welcome. That’s great to hear that switching to 60 Hz stopped the flickering. If you decide to replace the screen later or need more advice, feel free to reach out. Wishing you smooth use of your laptop in the meantime!
                        • TinyTool
                          • 357
                          By the way, is 60 Hz sufficient for daily tasks like browsing and streaming? I’m asking because I don’t feel any significant difference after downgrading.
                          • machinist
                            Moderator
                            • 386
                            You're totally fine with 60 Hz for everyday stuff. I get why you're not feeling much difference - most of what we do on computers like checking emails or scrolling through websites really doesn't need anything fancier. Even YouTube videos typically run at 30 fps, so you're already seeing them the way they're meant to be seen.
                            The whole high refresh rate thing mainly matters if you're into gaming or esports where every millisecond counts. For regular computer use? 60 Hz has been the standard forever for a reason - it just works!​
                            • TinyTool
                              • 357
                              #15
                              Oh, thank you for sharing this. I will use it on 60 Hz since it is working fine at the moment.
