RAM Compatibility: Same Brand vs. Same Specs
  • DarkKnight
    • 328
    Hi everyone!
    When installing a second RAM module, does it need to be from the same brand as the existing one, or is it enough for the modules to have the same specifications? Does using different brands impact performance or stability in any way? Thank you in advance!
  • machinist
    Moderator
    • 386
    Hi there!
    When installing a second RAM module, it doesn’t necessarily need to be from the same brand as the existing one. The key factors to ensure compatibility are matching specifications such as DDR generation (e.g., DDR4 or DDR5), speed (e.g., 3200 MHz), voltage, and timing (e.g., CL16). As long as these specifications align, different brands can often work together just fine.
    However, using RAM from different brands or with slightly different specifications might cause issues in rare cases, such as system instability or the modules defaulting to the speed of the slower one. To minimize potential problems, try to match the new RAM module as closely as possible to the existing one, and ensure your motherboard supports the total capacity and configuration.
    If you're adding RAM for a dual-channel setup, having identical modules is ideal for optimal performance, but it’s not strictly required. Modern systems are generally good at handling mixed brands as long as the specs match.
    • DarkKnight
      • 328
      Thank you for explaining this so clearly!
      I do have a question, though. How can I check the exact specifications of my current RAM module to ensure I’m getting the right match?
      • machinist
        Moderator
        • 386
        The easiest way is through your operating system. On Windows, open the Task Manager (Ctrl + Shift + Esc), navigate to the Performance tab, and click on Memory. Here, you'll see details like the RAM's speed (e.g., 3200 MHz), size, and type (e.g., DDR4). On macOS, you can click the Apple menu, select About This Mac, and check the Memory tab for similar details.
        If you need more in-depth information, third-party tools like CPU-Z, HWInfo, or Speccy (on Windows) provide details such as the exact model, manufacturer, and timings of your RAM. Alternatively, you can physically inspect the RAM itself. Shut down your PC, unplug it, and carefully remove a module. Look for a label on the stick that typically lists its type (e.g., DDR4), speed, voltage, and capacity.
        Lastly, it's important to cross-reference these details with your motherboard or laptop's manual to confirm what type of RAM is supported, including the maximum speed and capacity. This way, you can confidently purchase a new module that matches your system.
        • DarkKnight
          • 328
          Thank you, Machinist. It mentions the speed, 3200 MT/s but can't see if it is a DDR3 or DDR4.
          • machinist
            Moderator
            • 386
            Since 3200 MT/s is a standard speed for DDR4, it’s likely DDR4, but to be 100% sure, you should check using third-party tools like CPU-Z, HWInfo, or Speccy.​
            • DarkKnight
              • 328
              Yes, I also read somewhere that you can check through CMD, but even that didn't work for me. So now, a third-party software seems like the only reliable way to check. Also, I really appreciate all your help, thank you!
