Hey everyone, Is it worth upgrading from Windows 10 to Windows 11? TIA.
Is upgrading to Windows 11 worth it?
Hey! If you're happy with how Windows 10 is running for you, there's no rush to upgrade, but Windows 11 does offer some neat improvements, like a more streamlined interface, better virtual desktop support, and performance tweaks, especially if you’re using newer hardware.
The main thing to consider is whether your computer meets the requirements for Windows 11, especially the TPM 2.0 and Secure Boot. If you have the right specs and are looking for better performance or a more modern look, it could be worth upgrading. That said, if everything is running smoothly for you on Windows 10, there's no harm in waiting a bit longer to see if Windows 11 gets even more polished over time.
One thing to keep in mind with Windows 11 is that it's a bit picky about hardware compatibility. It needs TPM 2.0 and Secure Boot enabled, plus a fairly recent processor, like 8th gen Intel or 2nd gen Ryzen and up. If your system doesn’t meet those, you might run into issues or have to go through unofficial workarounds. Worth checking your PC Health Check app or the system requirements before making the leap. If you’re already liking the look and your hardware’s compatible, it might be worth a try!Comment
Thanks, Machinist!
How do I check if my system supports TPM 2.0 and if Secure Boot is enabled? I’ve never really looked into that before, so any tips would be great.It needs TPM 2.0 and Secure Boot enabled, plus a fairly recent processor, like 8th gen Intel or 2nd gen Ryzen and up.Comment
To check TPM:
Press Windows and R on your keyboard, type in "tpm.msc" and hit Enter. A window will open. If it says "TPM is ready for use" and shows version 2.0, then your system supports it.
To check Secure Boot:
Go to Start, then Settings, then System, then Recovery. Click "Restart now" under Advanced startup. After your computer restarts, go to Troubleshoot, then Advanced options, then UEFI Firmware Settings. From there, you’ll enter your BIOS or UEFI. Look for a Secure Boot setting. If it says Enabled, you’re good to go.
I’ve been using Windows 11 for a while now and it runs really smoothly on my system. For everyday tasks and multitasking, I haven’t noticed any slowdowns. It feels more refined compared to Windows 10. The interface is cleaner. As long as your hardware is compatible, you should have a good experience.Comment
My PC doesn’t officially support Windows 11, but I managed to install it using a workaround—you probably know what I mean. I have to say, Windows 11 has an impressive user interface and layout. The design is a big shift from previous versions, offering a more modern and streamlined experience.
That said, I don’t think upgrading to Windows 11 is absolutely necessary for everyone. But if you’re a tech enthusiast, it’s definitely worth checking out.Comment
I think you're right: it’s not something everyone needs to upgrade to right away. If Windows 10 is running fine, there’s no huge rush, especially if your hardware isn’t officially supported. But for those who like staying up to date or enjoy tweaking and customizing their setup, it’s definitely a fun OS to explore. Just depends on what you’re looking for from your system.Comment
Signal barely reaches my detached garage where I do most of my projects, and it's basically useless out there for looking up parts diagrams or streaming...
Channel: Computer Repair
