What are some basic tools every home should have for simple DIY tasks?
Basic DIY Tools
Hi there!
Some basic tools that come in handy for everyday DIY tasks include:- Screwdrivers (both flathead and Phillips)
- Hammer
- Measuring tape
- Utility knife
- Adjustable wrench
- Pliers (regular and needle-nose)
- Level
- Cordless drill
- Allen key set
- Small hardware kit with nails, screws, and wall anchors
These cover most simple jobs like hanging shelves, assembling furniture, or tightening loose hardware. Nothing too fancy, just reliable basics that make small repairs easier.
Great list so far! Just wanted to add a few more tools that can be really useful for basic DIY around the house:- Stud finder – super handy for safely mounting anything on the wall
- Painter’s tape – not just for painting, also great for marking measurements or holding things temporarily
- Caulking gun – useful for sealing gaps around windows, tubs, or sinks
- Flashlight or headlamp – helps a lot when working in tight or dark spaces
- Putty knife – good for patching holes or scraping off old material
These aren’t must-haves for everyone, but they definitely make certain jobs a lot easier if you do even occasional home maintenance.
Absolutely, you're right. Wire cutters are a great addition to the list.
They’re useful for small electrical fixes and even for things like opening tough packaging. Wire strippers are also worth having if you're planning to do any basic electrical work.
Thanks for pointing that out.
After the basic tools, the next step up in a DIY toolkit could include:- Jigsaw – useful for cutting curves or custom shapes in wood and plastic
- Multitool – great for sanding, scraping, or making small cuts in tight spots
- Orbital sander – speeds up surface prep and gives a smoother finish
- Voltage tester – important for safely checking electrical outlets and wires
- Clamps – handy for holding pieces together during gluing or assembly
- Socket set – better grip and control when working with bolts or nuts
- Wire stripper – helpful for clean, safe electrical connections
- Safety gear – gloves, safety glasses, and a dust mask are worth having around
These tools aren’t all must-haves right away, but they make certain projects easier and more efficient as needs grow.
A basic voltage tester works fine for quick checks like making sure an outlet is live or the power is off before replacing a switch. It's simple, cheap, and gets the job done for the basics.
But if you're doing more than just swapping fixtures or outlets, a multimeter is worth getting early on. It gives you actual readings for voltage, checks continuity, and helps with diagnosing electrical issues. Even for small DIY projects, it can save you time and uncertainty.
So while a basic tester is a solid start, a multimeter is a nice step up once you start digging into electrical work a bit more.
