Sump Pump
  • DIYER WANNABE
    • May 2010
    • 30
    Sump Pump
    I'm in need of a sump pump, and was curious what everyone thinks would be the best one for me? I don't want to spend a ton of money, but you can't put a price on a basement not flooding. I have the sump hole already.
    Thanks!
    any FLOTEC sump pump would do. a cast iron unit as opposed to a plastic body would be in order. get one with a 1 1/4 inch discharge.
    • DIYER WANNABE
      • May 2010
      • 30
      thank you i appreciate the info. is it hard to put a system in myself with drilling a hole in the house to the outside at all?
        Nope, quite easy I'd say. The hard part is drilling a hole to the outside. If you are going through wood and siding a regular hole saw that provides clearance around the pipe is needed. If you are going through concrete block or a concrete wall a diamond tipped hole saw is needed. Get a vertical check valve for the outlet and see if you can find a counter balanced exhaust cap like they use for tractor's exhaust systems. This comes with a collar for attaching to a pipe end. The pipe can be pvc or cpvc plastic.
        • DIYER WANNABE
          • May 2010
          • 30
          thanks for the info i'm still not sure if i'll do it myself yet, but it helps to know this stuff.
