Repairing Brick Wall After Stucco Falls Off
  • Roebling28
    • Mar 2003
    I own a 1914 home in New York where rear, exterior brick walls are covered with a stucco-like coating. During the winter, apparently after water seepage and freezing, large sections of the stucco have come loose from the wall -- re-exposing the brick. Sections of loose stucco ave taken off the outer face of the brick.
    1) Is repointing -- rather than recovering -- the newly exposed brick a repair option, given the damage to the brick face?
    2) If the brick should be recoated, what material is recommended? Stucco? Thoroseal? etc?
    3) Should a wire lathe be secured to the brick before a new covering is applied?
    Thanks in advance for any feedback you can provide.
