Focal Point Polyurethane crown molding install
  • Marjorie
    • Mar 2013
    Has anyone installed Focal Point "quick Clip " Poly Crown molding using ONLY an adhesive?? They recommend using "connector blocks" between pieces of molding...this results in a) a lot of waste because the connector blocks do NOT match the molding, they are simple blocks, b) they are unattractive, and c) require a lot of calculations for balance of pieces and cohesiveness in the room. After learning this, I really don't want to use the quick clip method because of this requirement. If you've used adhesive INSTEAD of the Quick Clips with this system, PLEASE tell me what/how/results ...TNX
