Dental handpiece maintenance and repair
  • Timavis10
    • Dec 2014
    • 5
    Hi there,
    Any tips for Dental handpiece maintenance and repair ?
    Thank you
  • ddddd1
    Banned
    • Dec 2014
    Daily cleaning as one of most effective methods. For some types of dental handpiece in dentequipment. co.uk, high quality without daily maintenance.
    • Timavis10
      • Dec 2014
      • 5
      Hi ddddd1, I am asking for tips for Dental handpiece maintenance and repair, Not a site for dental handpiece. I have much used dental handpiece to repair.
        I imagine the handpiece is the high speed turbo. It uses water as a lubricant and air pressure to power the turbine. If you can find the model number, go into dental appliances and try to find the exploded view. Then, maintenance should be a breeze. From what I remember, the tools [bits] press into the turbine wheel and lock in place. New bits are pressed against the old bits and push out of the wheel. Bearings would be water lubricated. Exit water helps cool the bit and flushes out the abraded tooth material.
