Hi, Can someone tell me how big of a pool pump I need for an Outdoor, Above ground Pool. Its 4 feet high and 12 feet across, round pool. Also if someone knows of any good spots to pick up pool equipment please let me know. Thanks Joe
Pool Pump
My guess would, well, just be a guess.
But here are some links that might be helpfull!
- http://www.electricmotorwarehouse.com/pool_filters.htm
- http://www.poolcenter.com/filters_ag_poolstor.htm
- http://www.propools.com/
you could work it out mathematically. The diameter is 12 feet so the area is pie x diameter or 3.1416 x 12=37.752 sq.ft.
depth is 4 feet so the volume is 37.752 x 4 = 2416.128 cu.ft.
one cubic foot of water equals approximately 8 gallons so the volume is 2416.128 x 8 = 2,416 gallons.
allowing that the water should go through the filter at least twice per hour you then have 2,416 x 2 = 4,832 gallons per hour divided by 60 minutes in the hour you have 80.53 gallon per minute.Comment
