sliding shower doors
  • Joyce
    • Aug 2005
    Can someone tell me how to replace the doors in the tracks after replacing the wheels. I only have a single track on the bottom, not a double one. When trying to reinstall doors, they are swinging freely instead of seating themselves securely in the bottom track.
    Are you talking about doorwall screen doors? If so, after setting the top into it's trackpath, get someone to hold it snug up there while you use a tool similar to a butter knife and lift the springloaded wheel 'till it clears the track and sets down on it. Do this for both wheels.
      The doors fit into a U shaped track that spans the upper part of the frame. This track can be lifted off the ends so that the doors can be fitted into the bottom track. Easier doing it with two people
      • neecee_2005
        • Mar 2007
        installing sliding shower doors
        IS THERE ANYWAY YOU COULD SEND A VIDEO OR DIAGRAM ON HOW TO INSTALL SLIDING SHOWER DOORS. I HAVE A U SHAPED UPPER PART BUT AT THE BOTTOM , ITS LOOKS LIKE A FLAT PIECE OF METAL WITH A LIP ON ONE SIDE. I DONT KNOW IF THERE DOUBLE SLIDING OR ONE IS SUPPOSED TO STATIONARY . I'M THINKING ONE IS STATIONARY THOUGH. IS THERE ANYWAY YOU COULD PLEASE SEND ME INFO. ON IT ! THANK YOU
        DENISE
          Shower doors
          The doors are meant to be able to slide past one another. On top of the panels is two sets of "bogie" wheels that fit into the "U" shaped upper track. One door's wheels fit into one "U" shaped track the other on the other side so they can slide past each other. Generally it's easier to install with two people. One holds the track - the other installs and holds the doors and track, then both place the track into the end supports whilst the other guides the doors bottom into the sill track.
