Is it possible to tile over an existing countertop without removing it without too much difficulty?
Kitchen countertop
Stacey,
Further to Troys post. As long as the current surface is stable and intact you can go over it using the right adhesive and surface prep. If the current counter is cracked, sagging or damaged (ie: by water) then you should remove it and start with a new good base.
Good luck, Jim
'Just a handyman trying to help''Just a handyman trying to help'Comment
y
