replacement window repair
  • armyvet
    • Feb 2006
    I need help repairing two small replacement windows. Top section of kitchen and 1/2 bath window have turned cloudy. How do you take the window apart to clean inbetween the glass and then reseal the window?
    You can't take the glass apart. In order to prevent condensation and clouding double pane window glass is sealed and slightly pressurized with an inert gas such as nitrogen. If the glass is clouding up on the inside that indicates the seals have failed.
    Some commercial glass supply houses have the equipment to custom make double and triple pane glass panels and they may be able to evauate the air out, then recharge the nitrogen and seal your glass.
