I had a new house build last year with a 3 car garage. (2 doors). I did a little research & bought two Genie Excelerator H8000D-2K garage door openers. I didn't have the time to install both so I only did the one for the main door (standard door) It worked great for about 5/6 months. The problem is that the light will turn on & off but the door will not open (if closed) or close (if already open). The remotes & the wall mount do nothing. So I unplugged it & plugged it back in.. (the lock is not on) it worked for about a week or so. (This went on for weeks) Now, I still have the same opener, new in the box for the 2nd door. So I pulled the motor & swapped it with the malfunctioning one. It worked GREAT!! I thought my problems were over.. Not so fast.. 3 months later.. It's doing it again.. I have 12 ft ceilings so pulling the ladder out of the shed 4 or 5 times a week was a pain in the butt. I went in the basement & clicked the circuit breaker off & on. Now.. It works again.. (for now) What could be the problem here?? Why do I need to keep reseting this damn thing?
By the way.. The door sensor lights are on & working fine.
Thank You for any help..
Carl
Carl
