Scratch marks on TV
  • Gardenboy
    • 334
    Scratch marks on TV
    Hi everyone! Does anyone know any home remedies for removing scratch marks from a TV screen? Thanks in advance!
  • FatimaandAhmed
    • 343
    Hey! Small scratches might be fixable with a little bit of petroleum jelly or a mix of baking soda and water. Just dab a tiny amount on a microfiber cloth and gently rub it in circles. If the scratch is deeper, a screen repair kit might be a better option.
    • machinist
      Moderator
      • 386
      Good tips! Another thing you can try is using a pencil eraser for very light scratches. Just gently rub it over the mark to see if it helps. If the scratch is still visible, a small amount of non-gel toothpaste can work too. Just apply a little with a microfiber cloth and buff in circular motions, then wipe clean with a damp cloth. Whatever method you use, be sure to test it on a small, less noticeable area first to avoid making things worse!
      • Gardenboy
        • 334
        Thank you for the suggestions!
        Do you think it’s safe for delicate screens like OLED?
        • machinist
          Moderator
          • 386
          For delicate screens like OLED, I’d be extra careful. Some cleaning methods, like using non-gel toothpaste or baking soda, might be too abrasive and could damage the screen's coating. Instead, a microfiber cloth with a tiny bit of distilled water or a specialized screen cleaner is the safest option. If the scratch is deep, a professional repair kit designed for screens might be a better option.
          • Gardenboy
            • 334
            Thank you for sharing this information. And what about scratch repair films for TV screens? Are they any good?
            • machinist
              Moderator
              • 386
              Scratch repair films can be a good option for minimizing the appearance of scratches on TV screens, especially if they’re shallow. They work by covering the scratch and diffusing light to make it less noticeable. However, they won’t actually remove the scratch, and results can vary depending on the screen type and severity of the damage. If you’re considering one, look for a high-quality, ultra-thin film designed for screens to avoid affecting picture clarity. If the scratch is deep or distracting, a professional repair or replacement might be a better long-term solution.
              • Alpha
                • 194
                Hello everyone, nice discussion! I want to know if these methods work on other types of screens too, like computer monitors or laptop screens, or if those need a different approach.
                • machinist
                  Moderator
                  • 386
                  Many of these methods can work on other types of screens like computer monitors and laptop screens, but it’s important to be cautious, especially with delicate displays like OLED or matte-finish screens. For glossy screens, a microfiber cloth with a tiny bit of distilled water or a specialized screen cleaner is the safest approach. Non-gel toothpaste or a baking soda paste might work on minor scratches, but they can be too abrasive for some coatings. A scratch repair film could also help minimize visibility on a monitor, just like on a TV. However, if the screen has an anti-glare or matte coating, using anything abrasive might make the damage worse rather than fixing it. If you’re dealing with a deep scratch, a professional repair kit or a replacement screen might be the better route.
                  • Alpha
                    • 194
                    That’s really helpful! Are there any specific screen repair kits you’d recommend, or are they all pretty similar in how they work?
                    • machinist
                      Moderator
                      • 386
                      Glad you found the info helpful! When it comes to screen repair kits, most of them work in a similar way, using either a mild abrasive or a filler to reduce the visibility of scratches. If you’re looking for one, I’d recommend going for a kit specifically designed for electronic screens rather than general-purpose scratch removers. Some kits use a liquid polymer that fills in the scratch and hardens, while others include ultra-fine polishing compounds. If your screen has an anti-glare or matte coating, be extra careful, as some kits can remove that coating and make the screen look worse. If the scratch isn’t too deep, a high-quality screen protector can also help mask it.
                      • Alpha
                        • 194
                        Thanks so much for all the helpful information!
