Monitor heaters
    Monitor heaters
    Now that its a little more warm outside, it's time to remove and overhaul your Monitor heaters. Don't wait until the middle of December to post your heater problems. Those of you with outdoor fuel tanks, use a drill pump hose and a plastic pipe to suck up all the water in the bottom of your tanks. Top off with fresh fuel. Blow out or vacuum the fins of the heat exchanger.
