Maytag Bravos XL Top-Load Washer Not Spinning – Troubleshooting Tips
  • machinist
    Moderator
    • 386
    Hi everyone,
    If you are facing a problem where the Maytag Bravos XL top-load washer (MVWB series) is not spinning properly, here are a few things to check and possible fixes:
    1. Lid lock not engaging – If the lid lock is faulty, the washer will not spin for safety reasons.
      Fix: Unplug the washer, check for damage or loose wiring, and clean around the lock. If it still does not work, replace the lid lock assembly.
    2. Worn or broken drive belt – A loose or damaged belt can prevent the tub from spinning.
      Fix: Inspect the belt for wear or looseness. Replace if frayed, cracked, or broken.
    3. Shifter actuator failure – This part shifts the washer from agitation to spin.
      Fix: If the washer drains but does not spin, the actuator may need replacement.
    4. Unbalanced load – Large, bulky items can throw the drum off balance.
      Fix: Pause the cycle, redistribute clothes evenly, and avoid overloading the drum.
    5. Control board issues – If all other parts are fine, the problem could be electronic.
      Fix: Check for visible damage on the board. Replacement is often best left to a technician.
    Keeping the washer level, avoiding overloading, and checking parts regularly can help prevent these issues.
    Hope this helps!
  • FatimaandAhmed
    • 343
    Thanks for the info! Is there a way to run a diagnostic mode on the MVWB series to narrow down the cause?
    • machinist
      Moderator
      • 386
      Hi!
      The MVWB series has a built-in diagnostic mode that can help narrow down the issue. It is usually entered by turning the washer’s cycle selector knob in a specific sequence. For most models, the steps are:
      1. Ensure the washer is in standby mode (plugged in but all lights off).
      2. Turn the cycle knob left one click, then right three clicks, left one click, and finally right one click.
      3. If done correctly, the control panel lights will illuminate, and the knob can be used to scroll through different test modes.
      From there, it’s possible to run automatic or manual tests to check the lid lock, motor, shifter actuator, and other components. The exact sequence can vary slightly by model, so the best reference is the tech sheet, which is usually tucked inside the control panel or taped to the cabinet.
      • FatimaandAhmed
        • 343
        Thank you! How are spin issues checked in diagnostic mode?
        • machinist
          Moderator
          • 386
          In the diagnostic mode of the MVWB series, there are specific tests that check the spin function. Once activated, the cycle selector knob can be used to navigate through various test options until reaching the spin test. During this test, the washer will attempt to spin the tub at different speeds to verify the operation of the motor, lid lock, drive system, and shifter actuator.
          If the tub fails to spin or spins irregularly during the test, this indicates a potential issue with one or more of these components. The diagnostic mode may also display error codes or flashing lights to help identify the exact problem. Running these tests can help determine whether parts require repair or replacement before disassembling the washer.
          For reference, the tech sheet inside the washer cabinet often includes a quick guide to diagnostic codes and test procedures.
          • FatimaandAhmed
            • 343
            Thanks so much for all the helpful information!
