Can Samsung automatic washing machines operate correctly if only cold water is connected to both the hot and cold inlets?
Samsung washing machine cold water for both inlets
Samsung automatic washing machines can generally operate if only cold water is connected to both the hot and cold inlets. The machine will fill, agitate, and spin normally, but cycles that normally use hot water will run with cold water instead, which can reduce cleaning effectiveness, especially on heavily soiled or greasy items. Some newer models include internal heating of cold water, but not all machines have that feature. It is also important to ensure the hot‑water inlet is properly capped if unused to prevent backflow or pressure issues. Checking the manual for the specific model will confirm how it handles cold‑only connections and whether any cycles are impacted. -
For Samsung washing machines with both hot and cold inlets, connecting cold water to both inlets will allow the machine to operate, but cycles that normally use hot water will run with cold water, which may reduce cleaning effectiveness, particularly on heavily soiled or greasy items. Machines without internal water heating will not heat the water, so energy use and cycle duration remain similar to normal operation. Machines with internal water heating may warm the cold water for certain cycles, so cleaning performance may be closer to normal, but energy use could be higher and some cycles slightly longer while the water heats. Checking the manual for the specific model will confirm how cold-only operation affects performance, energy use, and cycle behavior.Comment
Using only cold water for all cycles generally does not harm the washing machine itself. For cycles designed to use hot water, if the machine has an internal heating element, it will heat the cold water to the required temperature. This may slightly increase energy consumption and extend cycle duration, depending on the model, but it typically does not affect the overall lifespan of the machine.
Over time, detergents that are more effective in warm or hot water may leave more residue when washed in cold water, which could require more frequent cleaning of the drum, dispensers, or filters. Regular maintenance, as outlined in the user manual, will help keep the machine running efficiently, regardless of water temperature.Comment
The main impact of using only cold water for all cycles is generally on cleaning performance rather than on the washing machine itself. Machines typically operate normally with cold-only connections, and their components are not usually affected by lower water temperatures. On models that include an internal water heater, cold water can be heated for certain cycles, which may slightly increase energy use and cycle duration. On models without internal heating, cycles that normally use hot water will run entirely with cold water, which may reduce cleaning effectiveness, especially for heavily soiled or greasy items. The temperature of the cold water supply and the type of detergent used can also influence cleaning performance. Regular maintenance as outlined in the user manual helps maintain efficiency and longevity regardless of water temperature or model-specific features.Comment
Yes, it can work on some Samsung washing machines, but it depends on the specific model. If both the hot and cold inlet hoses are connected to a cold-water supply, the machine may still operate, but the water temperature options and certain wash cycles may not work as intended.
It’s best to check the installation instructions for your exact Samsung model before doing this. If the machine is showing an error, not filling properly, or having temperature-related issues, checking the inlet valves, hoses, filters, and water supply would also be a good starting point.
Yes, generally a Samsung washing machine can operate with only a cold-water supply, but it depends on the specific model. If you connect the cold supply to both the hot and cold inlets, the machine may work, but it won't actually have a separate hot-water supply. . It's better to follow the manufacturer's installation instructions for your specific machine.Last edited by admin; 09-22-2026, 01:42 PM.Comment
Good discussion. From the repair side, here is the practical summary for anyone setting this up:
Most Samsung washers will run fine with cold water feeding both inlets for everyday cycles (Normal, Quick Wash, Delicates, etc.). The machine does not know which supply is "hot" -- it simply opens the valve whenever the cycle calls for hot water.
A few things worth knowing:
- Cycles that need real heat (Sanitize, Allergen, Heavy Duty on hot) rely on the internal heater plus the hot inlet. With cold on both inlets, the heater has to do all the work, so those cycles run longer and use more electricity. If you use those cycles often, keeping a hot supply connected is worth it.
- Use a detergent formulated for cold water, and do not overdose it. Excess detergent plus constant cold washing is what leads to residue and odor buildup over time.
- Run the Self Clean cycle periodically, and leave the door or lid ajar between loads so the gasket and drum dry out.
- Practical tip: if you are splitting one cold line to both inlets with a Y-adapter, check the small mesh inlet screens on the back of the machine now and then. Restricted flow on one side is the most common cause of slow fills and 4C/4E fill errors.
- When disconnecting hoses, always shut the water valves off first and keep a towel handy -- supply lines are under full pressure.
Bottom line: for normal everyday laundry it works fine; just do not expect hot-water cycles to perform the same.Comment
by DownaskiCan Samsung automatic washing machines operate correctly if only cold water is connected to both the hot and cold inlets?
Channel: Appliances
