After a short power outage, my Maytag Gemini Gas Range upper oven came back on (it was on at the time the power outage occured) and now I cannot shut it off from the panel. I have tried to reset the oven to its factory settings but it did not work. In order to turn it off I have to pull the braker which is very inconvenient (When I reengange the braker it comes back on automatically). Please give me some direction as to what can be happening and how to troubleshoot/fix it. Thanks a lot.
Maytag Gemini Gas Range upper oven won't shut off
I'm afraid that is not enough information to identify the appliance in question. What is needed is its exact model number. If you post it we can at least look it up to see what components it uses.Maytag Gemini Gas Range
You can find tips for locating the model and serial number identification tag on your appliances at the following link:
LINK > Model Number Tag Location Guide
The power fluctuations may have damaged the electronic control or separate power relay board (if a separate component on whichever model range you have).After a short power outage... I cannot shut [upper oven] off from the panel.
Electronic controls are very prone to power surges and frequently need to be replaced after such an occurrence.
LINK > Appliances with electronic controls...
