i have a kenmore sideby side model 106.56546400 that is running fine on the freezer side, but the fridge side is not cold. I don't think the fan/blower that circulates the air is running. I don't see any ice build up. I have cleaned the condenser coil and still same result. where should i look next. ( i left the unit turned off for 24hrs to see if any ice that built up i didn't see would melt and the unit would work again, but same result after it has been running for the last 18hrs.)
kenmore freezer cold but not fridge side
Someone will need to look into why. The evaporator (freezer) fan motor should run whenever the compressor is. Proper cooling can not take place without it running.I don't think the fan/blower that circulates the air is running.
LINK > Kenmore 106.56546400 Evaporator Fan Motor
Appliance411.com
