Kitchenaid Refrigerator not cold
  • ddavid
    • Aug 2011
    freezer side working great, frig side not cooling well. Kitchenaid side by side model # KSRA25TLSS02. cleaned coils, they weren't that bad. Compressor was hot to the touch. unplugged electrical line for 20 minutes to let it cool. Plugged back in and still not cooling very well. Any ideas??
    Originally posted by ddavid
    Kitchenaid side by side model # KSRA25TLSS02. freezer side working great, frig side not cooling well. Any ideas??
    There are numerous things that could cause those symptoms. The most common possibilities are described at the following link. Each would have to be looked into one at a time until the cause in your case is found.
    LINK > My frost free refrigerator is not cooling properly. What might be the problem?
    JFYI
    • KWadden @ PartSelect
      Is ice also forming in your freezer?
      A common symptom when the fridge side is not getting cold enough is the freezer side also frosting up. If you notice this then it is one of three parts that is probably your problem 1: Defrost Timer 2. Defrost Heater 34. Defrost Thermostat
      Hope this helps!
