I have a Kitchen Aid oven that when we pre heat the oven we get a power failure on the display how can i fix an do u think it might be the mother board
Kichen Aid oven
It could be due to a failure in the electronic control itself, yes or maybe a problem with the power supply to the electronic control (or whole appliance).Originally posted by Gieredo u think it might be the mother board
Appliance411.com
The Appliance Information Site -
Proper terminology
The only appliance I know of that is said to contain a "mother board" is GE's electronically controlled refrigerator and it is actually just a slang term for its main electronic control (it could have several). "Electronic control" is the correct terminology although different manufactures might use a slightly different description for such a part but none are likely to use "motherboard".Originally posted by Gierewhen u say electronic control do u mean mother board ?
I don't know how whatever model of KitchenAid oven you have was designed (since you never supplied the appliance's model number as the forum instructions requested) but in most cases the electronic control is the actual component with the digital display.
JFYI
Appliance411.com
.Comment
