Is there oil, gear lube, or grease inside the transmission? The tub will turn with a wrench, but very hard. Thanks.
Maytag LA710 froze up
There is oil inside the transmission.Originally posted by ba_50
You mean like the tub would turn on spin?The tub will turn with a wrench, but very hard.
The insides of the transmission is for creating the agitation motion. The transmission locks up on spin and the whole transmission turns with the tub. If the tub won't turn, there might be a problem with the brake or the tub bearing the transmission goes through into the tub. There might also be the possibility of something caught between the tubs or around the transmission shaft.
You can find some service information about that Maytag washer design at the following link.
LINK > Maytag Dependable Care Washers
Appliance411.com
